Awesome. The TT overheated this weekend. Thought it was just electrical (because the coolant temp
Old Nov 9, 2004 | 08:33 AM
GreekTTCharlie's Avatar
Default Awesome. The TT overheated this weekend. Thought it was just electrical (because the coolant temp
light came on 30 seconds after turning the car on...and 3 mins later, the needle was buried on H.)
Evidently, I was wrong. The dealership just called, and evidently the whole coolant system was f*cked. Don't know specifics yet, but they said something about it all blew out onto the bypass valve?
Anyone have a similar experience or have any idea what caused this?
Old Nov 9, 2004 | 08:43 AM
fredfromny's Avatar
Default POS Audi plastic water pump impeller.
Fried my turbo and warped my head. Good luck.
Old Nov 9, 2004 | 08:53 AM
Default What what what?!?!?!
Same exact thing happened to you and did all that?
Old Nov 9, 2004 | 09:05 AM
fredfromny's Avatar
Default I had a stage 3 turbo...
And I drove it with the heater on after that. Hopefully you'll be OK.
Old Nov 9, 2004 | 09:11 AM
JustJeff's Avatar
Default Sure, No water=Lot's O-Heat=heat stress=warpage. Damn plastic crap
<img src="http://jbipes.home.comcast.net/jpgs/impeller.jpg">
<img src="http://jbipes.home.comcast.net/jpgs/impeller2.jpg">
<img src="http://jbipes.home.comcast.net/jpgs/pump1.jpg">
Unfortunately, the new pump is the same design.
Old Nov 9, 2004 | 09:17 AM
Default Funny... my heater was on when this all happened.
And when I got it to the dealership, I noticed leaking coolant dripping from the nose...kinda under the FMIC.
Old Nov 9, 2004 | 09:39 AM
CorrupTT's Avatar
Default (46k) two weeks ago, H20 pump went bad....
changed belt, tensioner, thermosat, fan switch.
Old Nov 9, 2004 | 09:43 AM
OldSchool AG's Avatar
Senior Member
how long did you drive it on "H"?
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 9, 2004 | 09:44 AM
fredfromny's Avatar
Hopefully you just had a leak and all is OK!
Old Nov 9, 2004 | 11:17 AM
Default Not long. Maybe 10 mins if that... she said my engine didn't overheat, which is weird...
But half way to the dealership, the needle flipped quickly all the way to C, and just stayed there.
Odd.
