Anyone has any good ideas about Ipod mounting locations? 02TTC here...
<img src="http://images5.fotki.com/v60/photos/7/7305/649935/DSC02117-vi.jpg">
And for the phone or Ipod, check out this....><ul><li><a href="https://forums.audiworld.com/tt/msgs/1157200.phtml">GadgetTT Post</a></li></ul>
GadgeTT Instructions
1)Grab the outer edge of your vent rings with your fingernails and pull the whole assembly straight out. Once started it can be wiggled and worked out of the dash easily. Getting it started is the hardest part here, but not hard! Remove both vents.
2)Place one ring of the GadgeTT over the vent assembly from the rear. Slide on all the way to the aluminum ring.
3)Push this vent back into its dash socket. Make sure it is aligned correctly.
4)Rotate GadgeTT so the other ring aligns with the dash cut-out.
5)Insert second Vent assembly.
6)Done!
Here's a page of RAM mount ideas:<ul><li><a href="http://www.gpscity.com/gps/brados/4721.1.2691110402514066786/rammounts.html">GPS city RAM parts</a></li></ul>
