CEL came on - could it be the gas?
Old Nov 10, 2004 | 12:37 PM
osuidoc's Avatar
Default CEL came on - could it be the gas?
Filled up with gas last week and was at an unfamiliar station and accidently put 87 octane in (cringe).
CEL came on 10 miles down road and thats when I pulled over a put some octane boost in. Used all the gas and yesterday filled with High test 94 octane and again put in octane boost but today the light is still on. Will this reset? The car seems a little short of maximum boost as well so did the computer reduce max boost while the light is on?
Help and advice please.
BTW - I don't have a VAG-Com.
Old Nov 10, 2004 | 12:43 PM
TTagz's Avatar
Senior Member
Default it will take a while to reset...
or I think you can unhook the battery for a little while and reset it yourself. you will have to enter the theft code for your radio afterwards though.
Old Nov 10, 2004 | 12:45 PM
osuidoc's Avatar
Is it just me or is the boost lowered when CEL is on?
OldSchool AG's Avatar
Senior Member
Default I've driven thru an entire tank of 87 that I accidentally put in>>
with no CEL, but I have no engine mods, and my car is a 180.
Then again, I didn't try for "maximum boost" after I made this error, and I'd recommend you don't either. See, with the lower octane juice in there, you definitely will have some detonation under heavy load which the knock sensor will report back to the ECU, and your timing will be retarded. The result will be less power.
Take it easy, run this tank completely out, then fill back up with 93. Should be fine. After you do that, you can reset the CEL (if it hasn't on its own) by unplugging the battery for a period of time (do a search, not sure as I have a VAG-COM).
See if it comes back on, if not, it hopefully was the gas.
Oh, and a word of advice on "octane boost" products. Read the fine print. Most products claim to "increase octane by X points." Well, wouldn't you like to know what a "point" is? 5 points in an average size tankful of 92 raises it to 92.5. Yeah, total SCAM!!!!
<a href="http://www.team.net/sol/tech/octane_b.html">Check it out</a>
Old Nov 10, 2004 | 12:57 PM
TTagz's Avatar
Senior Member
Default if detonation was detected , which is likely, you probably went into limp mode
so, yes the boost will be lowered.
Old Nov 10, 2004 | 01:21 PM
osuidoc's Avatar
So does this reset as well when CEL is off or do I need serviced?
Old Nov 10, 2004 | 01:54 PM
bubba j's Avatar
AudiWorld Expert
Default The ECU should detect and adjust for the low test fuel.
I don't see why this would throw a CEL.
Old Nov 10, 2004 | 07:28 PM
osuidoc's Avatar
How long do I have to wait. I tried a minute or so- no luck.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 10, 2004 | 07:29 PM
TTagz's Avatar
Senior Member
it's seriously like a week of regular driving before it will reset
ScratchRob13
Sep 22, 2008 05:14 AM
BluHeaven
20
Jun 9, 2004 04:21 PM
S6 4RiNGS
Audi Original "S" Cars
Apr 11, 2003 06:24 AM
Milehigh
Performance and Tuning
15
Nov 25, 2000 09:14 AM
