Yet another suspension question for the gurus...
Old Nov 10, 2004 | 09:16 PM
BTTI's Avatar
Senior Member
Default Yet another suspension question for the gurus...
I'm planning on the Bilstein/Eibach combo for the spring. I'm currently looking for 18 inch wheels - I have 17s currently. What I want to know is if I install the suspension and have the 17s on and then finally find a set of 18s, will it be okay to switch over? Is there anything to worry about with a bigger wheel? Alignment issues, camber adjustments, anything like that?
I'm also getting the Neuspeed 19mm rear sway bar. Should I do anything to the front?
Thanks to gurus everywhere!
Old Nov 10, 2004 | 09:18 PM
TTGram's Avatar
Member
The wheel will make no changes.
Old Nov 10, 2004 | 09:44 PM
That damn Dan's Avatar
Will if you incorporate spacers or a wider offset. 10" rims exaggerated my already negative camb
Old Nov 10, 2004 | 10:00 PM
meem's Avatar
Elder Member
changing diameter while leaving everything else the same will have no impact
Old Nov 10, 2004 | 10:01 PM
meem's Avatar
Elder Member
this was not the original question though
Old Nov 10, 2004 | 11:39 PM
JohnLZ7W's Avatar
No problems at all, that's exactly what I did.
Old Nov 11, 2004 | 12:28 AM
OK, bright eyes. You win.
Old Nov 11, 2004 | 04:47 AM
DerTT's Avatar
Default If the 18's are heavier >>>
then you may find the Eibach's not doing a good job controlling the motion of the wheels. From my experience with Eibach Pro-Kit springs on my GTI VR6, they were too soft and bottomed out often.
Not sure if that's the case with the TT, but just wanted to pass along the info.
Pal
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 11, 2004 | 06:43 AM
meem's Avatar
Elder Member
Default sorry, but one of the reasons there's so much confusion on this topic ...
is that people do a search and find replies stating both "yes" and "no", and don't know what to believe.
audia4turbov8
Apr 23, 2014 07:44 AM
audi1.8t4life
May 27, 2008 11:29 PM
silverTTQC
25
Aug 1, 2006 04:37 AM
SouthboroAudiGuy
24
Jul 22, 2006 04:04 AM
the centaur
Jan 25, 2003 02:14 PM
