Added TTDA to APR chipped 225 = -3 pounds less boost
So I get out to drive and it doesn't feel much (or any?) different. No surprise having just bolted it up on a 65 degree day but at least nothing bad happened :-)
Now the surprising part is that when I check the boost gauge I'm only boosting to 15psi (1.1 bar) rather than 18-19psi (1.4 bar) ... Felt as good as before prior to looking at gauge but now I'm not so sure - may be psychological ...
So I set the APR chip back to stock mode to check and surprise, surprise ... I'm only getting like 8-10 psi (0.7-0.8 bar) rather than 14-15 psi (1.0 bar) before.
I'll check all the obvious stuff on the weekend - make sure the air hoses aren't hard up against anything and blocked, check I haven't knocked any sensors loose, etc ...
But in the mean time, has anyone else experienced this or have any suggestions?
