will all 5x100 rims fit the TT, is the size of the center bore standard or should i be looking for a
Old Jun 19, 2005 | 11:57 AM
ttuner333's Avatar
Junior Member
Default will all 5x100 rims fit the TT, is the size of the center bore standard or should i be looking for a
specific number?
thanks
Old Jun 19, 2005 | 12:22 PM
blueprinTT's Avatar
Member
You'll need 57.1 mm center bore.
Old Jun 19, 2005 | 03:56 PM
MikekiM@PureMS's Avatar
Former Vendor
Default Or bigger
You can convert down using hubrings. Very common practice.
Just don't get a wheel with a center bore smaller than 57.1mm.
Old Jun 19, 2005 | 04:02 PM
ttuner333's Avatar
Junior Member
thanks guys!
Old Jun 19, 2005 | 05:03 PM
SereniTTy's Avatar
Default Hijack: Mike, do the 20mm H&R spacers have the bevel on them that the 12mm do?
I bought the 12mm spacers and can't use my hubcentric adaptors on them because of that bevel that goes from the spacer to the center of the spacer. The 12's are perfect up front, but they cause vibration. Right now I have them in teh rear (vibration isn't as bad), but I want 20's for the rear and to put the 12's back up front. I was thinking of havign a machine shop make me 2mm washers that are the diameter of the hubcentric rings, but I don't know if I will need 2 or 4.
Thanks,
Dan
Old Jun 20, 2005 | 07:59 AM
Former Vendor
Default Nope.
5, 8, 15, 20, 25 don't have that.
Only 8 w/lip, 10, and 12 do.
Old Jun 20, 2005 | 08:34 AM
maaliish's Avatar
also be carefull with width and offset.
bac2h
Q5/SQ5 MKI (8R) Discussion
May 26, 2016 02:34 AM
lsr78
Apr 25, 2005 02:00 PM
sTTay down
Wheels & Tires Discussion
Jan 31, 2005 06:53 AM
Bridge
Nov 14, 2002 07:13 AM
