Is the KMAC camber kit an easy installation or do you need special tools to get it done???
Old Jun 20, 2005 | 07:58 AM
mac0920tt's Avatar
New Member
Old Jun 20, 2005 | 08:03 AM
02TTK04's Avatar
Member
Helps to have the bushing extraction tool that comes with it. Other then that pretty easy.
Old Jun 20, 2005 | 08:06 AM
TTagz's Avatar
Senior Member
Default you need a good way to get the stock bushings out as 02TTK04 said...
if you order the KMAC kit it apparently comes with an extractor. My ecs 1/2 kit did not. you'll need a press or some kind of clamp assembly to get them out. other than that its a simple install. just don't smack yourself in the lip with a trailing arm while removing them like I did.
Old Jun 20, 2005 | 08:16 AM
dannyTTnyc's Avatar
Senior Member
Default the half kit might not come with the removal tool
and it was a PITA to get them out without it.
the degree temperature might have made it a bit harder as well
Old Jun 20, 2005 | 08:23 AM
02TTK04's Avatar
Member
Says on the ttstuff site that if you need it you can ask for it with the 1/2 kit.
Old Jun 20, 2005 | 11:40 AM
dannyTTnyc's Avatar
Senior Member
Default yup
just make sure you do!
ElemTTRo
Apr 15, 2005 09:27 AM
poopeter-el sigthief
May 15, 2002 08:15 PM
tt-3
Apr 25, 2002 05:43 PM
