My headlights are starting to wear. Can I buy the headlight plastic covers and replace myself?
Old Jun 20, 2005 | 09:38 AM
louiestt's Avatar
New Member
Default My headlights are starting to wear. Can I buy the headlight plastic covers and replace myself?
Or do I have to buy the complete headlight assembly?
Old Jun 20, 2005 | 09:46 AM
whodkne's Avatar
Member
Default Re: My headlights are starting to wear. Can I buy the headlight plastic covers and replace myself?
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1297002.phtml">https://forums.audiworld.com/tt/msgs/1297002.phtml</a</li></ul>
Old Jun 20, 2005 | 09:54 AM
louiestt's Avatar
New Member
Has anyone tried polishing the lens to remove the small sand pits? Is it possible?
Old Jun 20, 2005 | 09:59 AM
whodkne's Avatar
Member
Default There are plastic polishing techniques...
I'm sure one of the modcrazies will pop in.
Old Jun 20, 2005 | 10:19 AM
Seneb's Avatar
i've been told it can't be done because of a special coating on the lens.
Old Jun 20, 2005 | 10:22 AM
PGTT's Avatar
Default I used Novus plastic polishes years ago back when I was working with plastics.
Novus polishes might work on the polycarbonate (aka: Lexan) lense cover, but always test an inconspicuous location before doing the real thing.<ul><li><a href="http://www.noscratch.com/novus/index.shtml">Novus Plastic Polish</a></li></ul>
Old Jun 20, 2005 | 12:18 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default My body shop polished down some deep scratches. They are still there, but MUCH fainter than the
original damage. I do wish now I had demanded a new lamp, though...
Old Jun 20, 2005 | 03:49 PM
octo's Avatar
New Member
Default I did it.
Yes it is possible. I did it on mine - started with 150 (!) grit sand paper to get the real deep pits out and went progressively up to 2000 grit wet followed by rubbing compound, Novus 3 and Novus 2.
Lots of work and it won't be as clear as new because the lens has some "special" coating, which is obviously gone after sanding/polishing. Looks better than pitted, though...
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 20, 2005 | 07:21 PM
Basttion's Avatar
post pics!
audisession
Jul 29, 2018 09:27 AM
twiy
10
Dec 24, 2017 05:43 AM
brider
Audi allroad
Feb 14, 2012 07:02 PM
Bariukas
Sep 14, 2004 08:20 AM
mbr
Mar 16, 2003 06:13 AM
