Rough Idling on 2002 TT 225
I don't drive the car much, and so I left it in the garage over the winter, and this spring/ summer, the issue seems to have gone. Mind you that I did change to a FMIC over the winter, so I'm not sure if that has anything to do with it.
Good luck!
Change your fuel supplier and see if this persists. The varying RPM from 500 to 1500 is the overshoot the ECU is using to keep the engine running. ECU's have a hard time learning the volitility of fuel so they tend to do this, it's called RPM hunting.
How long ago (miles and time) did the DV get repaired and you go back to stock settings on Revo?
