Got bluetooth hands-free system to work with TT Bose system
As my TT did not come with any kind of cell phone prep, everyone told me there was no way to do it. However, I noticed on the back of the Bose Concert radio that there were three connectors - "phone mute", "tel +" and "tel -" - that must be useful for something.
The trick is to use a hands free set that has "line outs" that can be used instead of a separate speaker. The two that I found were the Motorola IHF1000 and the Parrot CK3000 and CK3100. I settled on the Parrot CK3100 (www.driveblue.com) which has a tiny LCD screen for caller ID etc.
The Parrot comes with a wiring harness that would probably work with non-Bose systems. For the Bose system, you cannot use the supplied wiring harness. You need to connect 6 wires: 3 for power (ground, always on 12 volts, and ignition 12 volts) and 3 to the back of the radio (tel mute, tel + and tel -).
Power connections are under the instrument panel - #75 is ignition switched, #30 is constant, ground connection is right under the steering wheel.
The Parrot CK3100 works with any Bluetooth phone. When a call comes in, the radio displays "phone" and you hear a ring through the speakers. Push a button on the LCD display and the conversation comes through the car's speakers. Even in the Roadster with the top down, there is very little echo or background noise. Best of all, it does not destroy the TT's looks - all you see is the tiny LCD control panel (about 1" tall by 2" wide). It works even when my cell phone is in my pocket.
I'd like to give a special thanks to the guys at Cell Comm in Falls Church, VA. They were very accommodating to let me do the install myself, helping out where needed.
Falls Church, VA 22046-2114 Phone: (703) 538-2500
I think the owner's name is Brian. I told him I appreciated his help & would post on the TT forum.
The display itself lights up blue, with red and green telephone buttons below it.
I installed on the left dashboard, below the vent and above the light switch.
When I get a chance I will post a picture. Meanwhile you can see what it looks like at the link below.<ul><li><a href="http://www.driveblue.com/Default.aspx?root=ck3100">http://www.driveblue.com/Default.aspx?root=ck3100</a</li></ul>
