feck...battery dead...question
Old Jun 22, 2005 | 09:38 AM
ebb(in memorium)'s Avatar
Default ****...battery dead...question
so car died, jumped it, let it run for 30minutes, turned it off and it wouldn't start again...it'll click once maybe 2x but it wont crank...
So is either the battery dead or is it another gremlin...
old TT went through 2 batteries and when they died they wouldnt even start when the batteries went..
any feedback?
thanks
Old Jun 22, 2005 | 09:58 AM
PGTT's Avatar
Default Jeesh! Never had any battery issues with either of my TT's.
Do you have any aftermarket accessories (amp, stereo, etc.) that might drain or strain the battery? Wonder if a marine battery can be fit into a TT? They generally are heavier duty.
Old Jun 22, 2005 | 10:54 AM
andrew.tt's Avatar
Default rule the batt out first. get it tested >>
autozone does it for free.
Old Jun 22, 2005 | 11:26 AM
Kareem of Elise's Avatar
Default My battery died a month ago, and after I put the new one in, I find out that....
the brake lights were stuck on and that's what drained the battery.......So I bought the $9 switch from VW, and replaced it......Wished I woulda known that before I dropped $100 on a battery....Oh well, at least I have a good Die Hard in there that'll last a long time.
Old Jun 22, 2005 | 12:23 PM
Default yep
small subw/amp...prolly sucking it dry over a long period of time...
Old Jun 22, 2005 | 12:25 PM
Default pretty sure it's the battery
drove 40 miles home after jumping it again and made it///no lights ac etc but I made it...if it was the altenator I doubt I could have made it since the battery was already toast...
Default yup checked that...
my sat radio "might" have been left on...
Old Jun 22, 2005 | 12:26 PM
hAUDIni's Avatar
Member
Default my battery went the day before TT East - or so I thought. All the usual symptoms....
of a dead battery or at least a low one. Turns out, it was just a precursor to my engine speed sensor going which kills all power to the car. That is an intermittent issue as the car started up again after a hard disconnect. Wonder if you have some sort of gremlin like that - not a constant but just a once in a blue moon loose connection or something? Doubt it's the issue but it's worth checking out as it's a rarity! A VAG would see a fault code for a sensor out of spec though if that were the case.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 22, 2005 | 12:27 PM
Default yea but the car would not start again w/out a jump...
but it did cross my mind...I already have the new battery so I'll give that a try 1st./..
aussigazza
21
Jun 14, 2013 05:53 PM
P
Dec 24, 2010 02:47 PM
SungTT
Jan 18, 2010 06:18 PM
SilvrBulleTT
New England Discussion
18
Jun 28, 2007 09:18 PM
BatteryProblem
Audi 100 / A6 (C4 Platform)
Jul 11, 2003 06:22 AM
