Bipes- or other with window squeek when going up or down- what lubrication should I use?
Old Jun 22, 2005 | 01:39 PM
HACK THS's Avatar
Default Bipes- or other with window squeek when going up or down- what lubrication should I use?
I don't remember what I used last year, but it is back again. I remember it was a spray, don't think it was WD-40, I need something to spray lubricate the cable that pulls the windows up and down. It was SOOOOOO nice last year when I FINALLY got it fixed. In case some of you have the problem, the part that needs to be lubricated is the cables that goes into the white plastic piece INSIDE the door, seems something in that motor is squeeking, and lubricating the cable solves it, at least for a year.
Any recommendations for a good lube?
Old Jun 22, 2005 | 01:51 PM
blissfull's Avatar
Elder Member
wow this post would be fun in AWOT
Old Jun 22, 2005 | 02:01 PM
whodkne's Avatar
Member
White Lithium Grease.
Old Jun 22, 2005 | 02:02 PM
HACK THS's Avatar
Where do you get that? Ace Hardware?
Old Jun 22, 2005 | 02:06 PM
OldSchool AG's Avatar
Senior Member
yep, or home depot. probably should get the spray bottle kind.
Old Jun 22, 2005 | 02:15 PM
Seneb's Avatar
KY warming?
SantaCruisin
Oct 18, 2005 05:56 PM
MrPolak
Oct 28, 2002 08:05 AM
