Slight Mod to the Mod...................
<img src="http://images12.fotki.com/v242/photos/6/645139/2927227/rightichose020-vi.jpg">
So a little cutting, grinding and sanding made the excess bolt disappear. Really thought Stainless was harder to cut. You can also see the clamp is behind the front flange by the slight buldge, shown here.
<img src="http://images12.fotki.com/v251/photos/6/645139/2927227/rightichose022-vi.jpg">
A safe way to do this would be to tighten the clamp, then loosen it until it is just loose enough to be able to rotate and slide the clamp. Then cut the bolt flush with the nut at that point.
