Fuel Gauge Reading Incorrectly
Old Dec 4, 2005 | 12:08 PM
HwyTT's Avatar
Default Fuel Gauge Reading Incorrectly
My fuel gauge will read just over half full when actually empty(didn't find out the hard way). I recently added a compustar remote start/alarm and removed the inst cluster. Anybody have any ideas?Can this gauge be adjusted?
Old Dec 4, 2005 | 12:13 PM
blackfnTTruck's Avatar
Could be a faulty sending unit, seems to happen quite often.
Old Dec 4, 2005 | 12:22 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You may get lucky.....>>
if it's the senders. Run a few bottles of Tecron through the car during your next few fill-ups and see if that doesn't clean the sender contacts and bring the gauge back to life. This recently worked for me. You can also remove and clean them but it's a bit more involved. If neither of those works, you may be due for a cluster....Flukey gauge readings are one of the early symptoms..
Old Dec 4, 2005 | 12:43 PM
RoberTT-WWCD's Avatar
Default Link to fuel sender repair...>>
Try the passenger side first. Process takes about an hour.
Note: if you don't have access to the tool, the Audi dealer might let you borrow one.<ul><li><a href="http://public.fotki.com/RoberTT/maintenance/repairing_fuel_sender/">Fuel sender repair...</a></li></ul>
Old Dec 4, 2005 | 02:47 PM
Kinetic0510's Avatar
Member
Default One time my gas gauge flaked out on me also...
All it took to fix it was a fuel fill-up at the local gas station and that seemed to fix/reset the incorrect needle reading. Issue never returned, that was almost a year ago.
Old Dec 4, 2005 | 03:01 PM
Neo1130's Avatar
Junior Member
Default I've had that... Seems if I let my car go below the first red mark and shut the car off and on....
It won't go back to normal until I fill... It will actually sit on 0 Gallons... Even if there is 1/4 tank... Only back to normal with a FULL tank...
Old Dec 4, 2005 | 06:29 PM
GoTToGo's Avatar
Junior Member
Default Anywhere else to get the tool?
Or any suggestions on a more common tool substitute?
Old Dec 4, 2005 | 06:58 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
You can just tap the rings with a drift to unscrew....
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 5, 2005 | 08:59 AM
Thanks Steve. Just saw the response. Once loose, it turns easy.
pal joey
Audi A5 / S5 / RS5 (B9)
Aug 6, 2017 11:25 AM
ITALSKIER
Jul 1, 2007 02:40 PM
AudiSport4000
Jan 13, 2006 01:42 PM
STEVE2.7T
Feb 12, 2001 09:41 AM
