HELP - 03 CanBus aftermarket HU install gone sideways - wiring appears to be much different...
Old Dec 4, 2005 | 02:14 PM
joe@vwvortex's Avatar
Default HELP - 03 CanBus aftermarket HU install gone sideways - wiring appears to be much different...
<center><img src="http://www.rastta.com/images/radio.jpg"></center><p>Here's a pic of the back of the Concert II. I'm using the same Metra Harness as everyone else - including MarTT. However, it appears I don't get illumination power or ignition power in the small 8pin connector. When I plug in the Headunit - I get power but it does'nt light up or "turn on" so to speak. Also - the radio itself shows 6 pin outs for the line outs - but the actual plug in the car only has 4 - not sure why that is.
Old Dec 4, 2005 | 02:32 PM
SpoiledHeeb's Avatar
Default The lineout uses a common ground >>
so on the metra harness that connects to the lineout portion of the car connector, there should be a black wire that needs to be connected to ground...
Old Dec 4, 2005 | 02:35 PM
MarTT's Avatar
My Alpine HU harness did not have a wire for illumination (therefore it does not dim).
Old Dec 4, 2005 | 02:37 PM
Default What about the 12V switched and illumination? Where did or do you source that?
That is what appears to be my problem.
Old Dec 4, 2005 | 02:46 PM
MOBlueTT's Avatar
Member
Joe, Don't you want to leave your radio on and drain the battery? ;-P
Old Dec 4, 2005 | 03:16 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You may have to go to the source Joe...>
75A lug under the dash, and the light blue lead coming off the headlight switch..
Old Dec 4, 2005 | 03:33 PM
Default Yeah - I tapped a switched fuse to see if it would work and it did but no sound is coming out
i've tried multiple combinations of the lineouts using the metra harness. What I don't understand is that this is the one thing that SHOULD be the same between the old and the new concerts.
Old Dec 4, 2005 | 03:42 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ha ha...That happened to me the first go-round...>
Make sure you hook up the Bose Amp power lead pin to a switched source. Probably the pin marked "Bose" and a lead off your head unit for amp power.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 4, 2005 | 03:55 PM
Default When you connected the line outs you have to also connect a power source...
for the bose amp or did your's power through the line out connector of the metra?
Old Dec 4, 2005 | 03:59 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Line outs are only for the audio signal...>
You must power the amp as well. Mine was done through the Metra harness (Remote amp switch on as seen here)
<img src="http://images15.fotki.com/v229/photos/7/7305/2716528/headunitwiring-vi.jpg">
