Help - brake bleed question...
Problem now is mushy brake pedal and brake warning symbol on info panel. Car does stop, but I would hate to try an 80 mph panic stop.
Did I not run enough fluid out?
Do I need to bleed all 4 corners?
Need to fix this tonight.
Thank God for the garage; it's f'n cold out.
Pads are champhered. Sprayed the anti-squeal stuff on back of pads. Also used a product from ECS that sprays on pads and rotors. Some aluminum based anti-squeal product.
Started bedding procedure you described, but too many cars on road. Will try later tonight. Meanwhile, will bleed fronts a bit more.
Done many cars and that always works for me.
<img src="http://pictureposter.audiworld.com/77447/brakebleed1.jpg">
Did left rear, then right front. Was able to do the fronts with wheels mounted. I had already pulled them twice. Notice how clean the winter wheels look? Washed and waxed em today:
<img src="http://pictureposter.audiworld.com/77447/brakebleed3a.jpg">
Here is worm's eye view of right front bleeder nipple with vacuum bleeder in place. It barely fit with 16x7 rim. ET40 offset just clears calipers.
<img src="http://pictureposter.audiworld.com/77447/brakebleed3b.jpg">
Did 2 sets of 10 panic stops from 40-50 to about 10-20. The smell of toasty pads lingers in the 14F air tonight.
Thanks all for your advice.
