can i just get the band clamp for the CV joint, also PCV question ...
while doing my 40k maintenance this weekend, i found a freshly loose front inner boot. grease had just barely started coming out of it. so i cranked on the one time use clamp with some strange hammerhead shark nosed wire cutters and got it a little tighter. can i source just the clamp or what, the boot is fine and grease is in tact. i have a CPO and i might try to get one out of the dealer, but i'm not holding my breath. i was going to use a regular hose clamp but the clamp mechanism seems to be a bit too high profile. is there a tool for the audi clamps that i can find for cheap?
also, i took off the lower hose to the passenger side intercooler and oil dripped out. i had a feeling there were PCV problems due to oil consumption levels. dripping oil is too much right? i'm also going to see if the dealer can cover this with the CPO, i'm sure they will say that "there's always going to be some oil" but i want to know if it should or shouldn't drip.
other than that all the other 40K stuff was a breeze.
thanks
Before I do another, I'll order the right tool. I've seen it for around $20 online.
thank you for your help. i hate letting those muppets touch my baby.
<img src="http://store1.yimg.com/I/brandsplace_1870_9527069"><ul><li><a href="http://shop.store.yahoo.com/brandsplace/0246-lis30800.html">http://shop.store.yahoo.com/brandsplace/0246-lis30800.html</a</li></ul>
