Temp Gauge Readout
Old Dec 4, 2005 | 06:43 PM
gomezTT's Avatar
Default Temp Gauge Readout
Here's my question....since there is a fair amount of discussion about water pumps, thermostats, clusters etc. I wonder about this - if I idle my 02 225 for more than a few minutes, the temp gauge will move from dead center upward a full increment toward hot then cycle back down to the center positon. Stays at center while driving and has not overheated. Is this normal? Should I have it looked at by the dealer (still under warranty). Please advise - only had this car seven months. My last TT never did this.
Old Dec 4, 2005 | 07:00 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Perfectly normal.......>>
With no cooling air flowing through the radiator, the temp rises until the set point of the fan temp switch is reached, The fan activates and cools the car back down. It will continue this cycle if you stay stopped and idling..
Old Dec 4, 2005 | 09:38 PM
OldSchool AG's Avatar
Senior Member
yup. unless a/c compressor is on-- that runs the fans constantly
Old Dec 4, 2005 | 10:19 PM
Miah_S4Avant's Avatar
Default Not necessarily normal. Mine did that, and the cluster was replace... never does it anymore even in
hot temps.
Old Dec 5, 2005 | 06:26 AM
Senior Member
i'd say that's not normal... but if you like that behavior.... i think all fords do it!
Old Dec 5, 2005 | 07:17 AM
bubba j's Avatar
AudiWorld Expert
Default In cooler weather, mine idles at 12 o'clock and cruises at 11.
You might try turning on the A/C to see if that holds the needle more steady. If so, then your "problem" is a fan switch of some sort.
Old Dec 7, 2005 | 06:50 PM
gomezTT's Avatar
Default Re: yup. unless a/c compressor is on-- that runs the fans constantly
A-HA! That fan cycling activity explains why I did not have this happening in the summer months...yet I did notice it in these cold days without the ac turned on. I first noticed this while letting the car idle on a cold Sunday morning while ogling new Audis on the dealer's lot. Thanks for the info. Click and Clack have nothing on us as far as diagnostics is concerned!
sidespar
Oct 24, 2007 08:23 PM
CheeseHead Cubs Fan
Oct 1, 2004 12:30 PM
4000skq
Nov 1, 2003 07:05 PM
petersthompson
Apr 19, 2002 08:59 AM
