Command vs intercooler pressure readings
Old Dec 5, 2005 | 01:27 AM
Rai's Avatar
Rai
Default Command vs intercooler pressure readings
Found a few loose hoses over the weekend that have been wreaking havoc with my car... everything back in place and tightened up i'm now paranoid and looking for leaks (got to get me one of Steve's pressure adapters).
Couldn't get a good traffic free run but managed to log a small high gear run tonight.
<img src="http://xs58.xs.to/pics/05491/cmd_int_press.JPG">
Given intercooler pressure is close to command once the turbo has built boost at ~3K everything looks healthy to me. Any comments?
Old Dec 5, 2005 | 05:13 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Looks fine Rai....You're probably making more boost though...>
As the MAP sensor, and hence VAG-COM can't read over 2560 Milibars...
Command pressure is very aggressive...What chip?
Old Dec 5, 2005 | 05:18 AM
Rai's Avatar
Rai
Default Hi Steve... MTM. Boost gauge is only registering about 1.5 Bar...
i didn't log it but would manifold pressure, ie. where the boost gauge is plumbed in, be expected to be a shade lower?
Old Dec 5, 2005 | 05:42 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ah!, I remember now...Usually it's higher....>
but it Looks like everything is coming together in one spot which is OK (1.5 bar). Many times Actual and IC boost will be above command. When everything lines up like that, the car is able to deliver exactly what the ECU is telling it to. (This is a good thing!)
Old Dec 5, 2005 | 06:46 AM
BigTT's Avatar
Member
Default Steve, since you are the resident expert ;)......`
what do you make of a dip in the command/intercooler/manifold pressure starting at 4K (2300mbr to 2090mbr)? Been trying to figure out why the car looses omph as the revs go up... I can see the boost dropping and the seat dyno correlates... Wonder how much this is the MTM chip not liking our ****ty Cali gas....
Old Dec 5, 2005 | 07:45 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ted...seen that before...>>
Believe it or not, the temp sensor has been the culprit in a couple of cases. If you haven't upgraded to a new green one, spend the $6!!
Old Dec 5, 2005 | 09:34 AM
BigTT's Avatar
Member
Default Hmmm... I'll give it a shot... I did some 4th gear runs this morning as well...
it looks like the MAF numbers never get above 160g/s May have that as a culprit as well... Is the temp sensor available at ECS???
Thanks
T
Old Dec 5, 2005 | 10:35 AM
maaliish's Avatar
Default What chip do you have? Mine never requests more then 2500, let alone sustain it for that long.
What mods are you running?
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 5, 2005 | 10:40 AM
maaliish's Avatar
Default FYI, on brand new MAF and Green temp sensor I still see the exact dip in requested CMD press on my
car. I have an APR chip though...I see now that you have MTM. Even with the boost machine I have problems keeping boost above 2100 when RPMs start approaching 5K.
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ooops...That's a problem too...>
Should be 180-190. Ecs has both...:-)
