Remember this?.........
The 225 TT Dual port Programmer, they also have a 180 version, at the TT Shop. I emailed them to see if it would work on US TTs, here is their reply:
Hi Robert,
The dual system will also work on the American TTs. We also do the chip
changes, but you would need to send us your ecu.
Best regards, Alex
Alex Kerr
Alex@thettshop.com
The TT Shop - www.thettshop.com
t : 01234 853 225
f : 01234 854 225
The one stop shop for your AudiTT
REALLY??<ul><li><a href="http://www.thettshop.com/performance.asp?cat=3058&product=701453">Dual Programmer</a></li></ul>
With regard to the One Click this is not a problem to post it to you, we would need to know your ECU number, do you have access to VAG Com to obtain this? If not we will have to post you a blank One Click so you can down load the map and then you would need to post it back to us so we can send the modified one back to you. As you can see this is much easier if you can let us know the ECU number.
