leaky CV? boot, how critical to replace?
Old Dec 5, 2005 | 11:05 AM
Matt Devo's Avatar
Default leaky CV? boot, how critical to replace?
was doing an oil change yesterday on my mother-in-law's TT, and saw this underneath. Is it critical to replace it asap, or?
TIA
<img src="http://pictureposter.audiworld.com/52813/leak_sm.jpg">
Old Dec 5, 2005 | 11:31 AM
dougie's Avatar
25 Year Member
~$30 part ~$60 labor. just do it.
Old Dec 5, 2005 | 11:32 AM
jhoeppel's Avatar
Default Similar issue discussed yesterday
Check the post &lt;link below&gt; from yesterday... not sure how much of a PITA replacemant is.
So what you do probably depends on how much grease was lost. If the boot isn't split, perhaps you can reinject grease and tighten or replace the clamp. OEM clamp isn't reusable thought. Check the link to a more complete discussion...<ul><li><a href="https://forums.audiworld.com/tt/msgs/1401437.phtml">Click for another recent CV boot issue</a></li></ul>
Old Dec 5, 2005 | 11:44 AM
Matt Devo's Avatar
Default I don't see a clamp on there, or am I blind?
it doesn't appear that the boot is torn, but I'll double check tonight
Old Dec 5, 2005 | 11:48 AM
jhoeppel's Avatar
Default Damn... you're right! I'd inject grease and reclamp...>
<center><img src="http://pictureposter.audiworld.com/65932/cvjoint.jpg"></center><p>
It's prob'ly obvious, but there should be one where I've marked a yellow band. IIRC you need some sort of special tool to tighten the OEM Audi clamps, but maybe there are other types usable.
Your M-I-L's original clamp must have broken and fallen off. I'd reseal it soon to prevent dirt and other abraisve crud from getting, inside and slowly grinding up the CV joint itself.
Old Dec 5, 2005 | 11:52 AM
jonchavez's Avatar
Member
really? who does it for that price? the dealer?
Old Dec 5, 2005 | 11:59 AM
BierBurner's Avatar
Default Good Idea,
Just make sure that no dirt/debris got in back some grease and re-clamp it.
Old Dec 5, 2005 | 12:07 PM
Matt Devo's Avatar
what do I need to do to regrease? can I use a non-OEM clamp?
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 5, 2005 | 12:12 PM
TTagz's Avatar
Senior Member
try more like $350
Old Dec 5, 2005 | 12:37 PM
dougie's Avatar
25 Year Member
what? i had the outer passenger CV boot replaced at an indie for $60 labor. or was it inner?
