VAG-COM Interfaces: KEY or HEX?
Old Feb 11, 2006 | 11:38 AM
AdamHoward's Avatar
New Member
Default VAG-COM Interfaces: KEY or HEX?
Is there any reason to buy the more expensive HEX interface for my '01 180TTQC?
Thanks.
Adam
Old Feb 11, 2006 | 11:47 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
The basic set-up will do all you need it too...
Old Feb 11, 2006 | 11:52 AM
AdamHoward's Avatar
New Member
Default Re: The basic set-up will do all you need it too...
I noticed the site described a speed increase for the HEX interface. Do you know if this only applies when the car uses the CAN bus?
Old Feb 11, 2006 | 11:58 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Dunno, but..>
For normal Fault code checking and logging you'll be fine with the basic set-up....Logging with the standard set-up is approx once/sec. which is generally OK for most any diagnostic chores. If you have the $$ and want to go with the best, get the faster interface..
Old Feb 11, 2006 | 12:03 PM
AdamHoward's Avatar
New Member
Thanks
JakBeatZ
May 26, 2009 06:11 AM
Lauda81
Jun 23, 2008 03:00 AM
S4ptld
VAG-COM Discussion
May 8, 2007 03:56 PM
melsas
VAG-COM Discussion
May 2, 2007 10:52 AM
xtrac
Jan 30, 2001 11:44 AM
