Can I put staggered rims/tires on Quattro?
Old Feb 11, 2006 | 12:36 PM
as350's Avatar
Member
Default Can I put staggered rims/tires on Quattro?
I am looking at the following set:
- front 18 x 8.0, 225/40/18
- rear 18 x 9.5, 265/35/18
Since I have AWD, I am fully aware that the front and rear tire circumference have to be identical. But it has been too long since a professor made me apply the formulas and I am looking for some help from forum members.
Does this setup make any sense at all? Tips, hints, etc. are greatly appreciated.
Old Feb 11, 2006 | 12:52 PM
Laguna's Avatar
The front circumference is 78.8 vs 79.5 for that set configuation. Does it make a difference? It may
Old Feb 11, 2006 | 01:35 PM
as350's Avatar
Member
Is there a staggered setup that is identical front/rear?
Old Feb 11, 2006 | 01:43 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You'll need a tire size calculator...>>
But willl be better off with specific manufacturers specs as they vary even in identical sizes. Search google for tire calculators...There's a zillion out there...
Old Feb 11, 2006 | 01:55 PM
Russ Scott's Avatar
Default usually 235/40's match up best with 265/35's :-)
here's a useful reference...
most manufacturers are represented on this Tire Rack chart:
*pick and click your tire
*click on "specs"
*select your proposed size(s)
*go accross the chart to find "diameter"
for example: Bridgestone Potenza SO-3's
225/40-18 diameter = 25.0 inches
235/40-18__________25.4
255/35-18__________25.0
265/35-18__________25.4
So:
225/40-18 works best with 255/35-18
235/40-18 works best with 265/35-18<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&amp;url=%2Ftires%2Fsurveyresults%2Fsur veydisplay.jsp%3Ftype%3DMP">Tire Rack tech page:</a></li></ul>
Old Feb 11, 2006 | 02:25 PM
as350's Avatar
Member
Thanks
Old Feb 11, 2006 | 02:48 PM
Paldi's Avatar
Default Here's one in a zillion. :-)
<ul><li><a href="http://www.miata.net/garage/tirecalcold.html">http://www.miata.net/garage/tirecalcold.html</a</li></ul>
Old Feb 11, 2006 | 03:38 PM
as350's Avatar
Member
Thanks for the link. It answered another question of mine.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2006 | 05:44 PM
Basttion's Avatar
Default Tire rack just told me yesterday that Audi only supports
the following:
225.45.17
225.40.18
235.35.19
He said anything else will throw off the speedo, which will throw off everything from the timing to the fuel injection, to yada yada yada, on and on.
Was I told incorrectly?
His name was Doug at extension 388
Old Feb 11, 2006 | 07:18 PM
sonus's Avatar
If going custom multipiece wheels, you could have the offsets varied instead, for a staggered look
