who here has a Neuspeed (or other aftermarket) FRONT sway bar installed?
Old Feb 11, 2006 | 04:19 PM
|everso!|'s Avatar
Default who here has a Neuspeed (or other aftermarket) FRONT sway bar installed?
i have a 22mm rear installed, and was thinking about adding a thicker one to the front for more rigidity.
any thoughts/impressions?
Old Feb 11, 2006 | 05:43 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Me!
With a 22 rear you'd be advisd to bump the front... PITA install though (subframe drop)
Old Feb 12, 2006 | 01:46 AM
supersTTar's Avatar
New Member
Default i do
<center><img src="http://i2.photobucket.com/albums/y42/taurusmisu/wintersetup.jpg"></center><p>
ihv the 21mm neuspeed front! loving it installation's a biotch tho
Old Feb 12, 2006 | 06:49 PM
JohnLZ7W's Avatar
Default How bad is the subframe drop?
I was thinking about doing the poly bushings for the steering rack but that apparently requires dropping the subframe. Since no one has tried them yet I'm a bit hesitant to do all that work (read: have Brad do all that work
Old Feb 12, 2006 | 06:55 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Those bushings are in there somewhere!
I don't think those are a big problem....You've got Mark 1's.....
<img src="http://images6.fotki.com/v100/photos/7/7305/1232358/DSC02592-vi.jpg">
Old Feb 12, 2006 | 06:57 PM
JohnLZ7W's Avatar
yeah the mk1s are great... until I ride in the S2000
unc99206
Feb 7, 2007 12:53 PM
mattchow
Apr 7, 2005 06:00 PM
troyegly
Jul 22, 2004 04:25 AM
4Rings::G2 boosted::
Apr 12, 2003 06:04 PM
ND4SPEED
Apr 22, 2002 08:36 PM
