2nd post same question. About this euro plate........
Old Feb 12, 2006 | 05:37 AM
Arheddis Varkenjaab's Avatar
Junior Member
Default 2nd post same question. About this euro plate........
I have taken the plate off the front of my car. Should a drill holes in my bumper to hold the frame or would 3m trim tape work?
Old Feb 12, 2006 | 05:55 AM
JustAdam's Avatar
Search for magnets - lots of people have done this - no drill holes please
Old Feb 12, 2006 | 06:17 AM
PGTT's Avatar
Industrial quality 3M double-tack tape works fine.
Old Feb 12, 2006 | 06:25 AM
stilljester's Avatar
Member
Ok....Did you remove the body colored insert?
Old Feb 12, 2006 | 06:29 AM
Junior Member
Default I used that yasterday and it didn't seem strong enough?
it was cold out so i pulled into the garage and used a heat gun on the frame the tape and the bumper to try and help the adhesive.
Old Feb 12, 2006 | 06:32 AM
PGTT's Avatar
Default Definitely use on a very clean, warm surface and let it set as those tapes need a little time to set
Gina (cubstter) has a front Euro plate on her car using this tape, been on for 3+ years without issue.
Old Feb 12, 2006 | 06:53 AM
Member
Default After removing the bumper insert I put screws here:
<center><img src="http://www.rpi.edu/~onksej/Audi%20Stuff/plate.JPG"></center><p><img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Plate.JPG">
rolledthatho
Jan 29, 2005 02:36 PM
rolledthatho
Jan 29, 2005 10:23 AM
wolv1414
Nov 8, 2003 07:29 AM
saabSean
Nov 11, 2002 12:16 PM
