Let's just say, (for sake of argument) that I were to mount 5x112 ET 20 wheels to my TT.
Old Feb 12, 2006 | 10:55 AM
Basttion's Avatar
Default Let's just say, (for sake of argument) that I were to mount 5x112 ET 20 wheels to my TT.
What would be some of the negative things that I might expect to run into.
I know I would need adapters and would proably need tuner lugs. Anything else come to mind?
Thanks!
Old Feb 12, 2006 | 10:57 AM
sonus's Avatar
Assuming the width is no less than 8 inches, ET20 plus adapters would stick out of the wheel wells
Old Feb 12, 2006 | 10:59 AM
Basttion's Avatar
Default They are 8s, but according to meem's calculator, they would be inside the wells
by 4mm front and 10mm rear.
sonus's Avatar
So, what is the width of the wheel, and out of curiosity, what wheel are you considering?
Old Feb 12, 2006 | 11:01 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default No good then...Usually adapters are at least 20mm....
YOu need that thickness to recess the attaching bolts..
Old Feb 12, 2006 | 11:02 AM
sonus's Avatar
Default That's using meem's calculator and not taking into account the width of the adapters>>
The thinnest adapter that you can find would probably be 20mm. So taking that into account at the very least, you would be 24mm outside in the front, and 30mm outside in the rear.
Old Feb 12, 2006 | 11:05 AM
Cameron's Avatar
AudiWorld Uber User
Uh... since the TT isn't 5x112, I think that'd be a problem.
Old Feb 12, 2006 | 11:08 AM
Basttion's Avatar
can you be a bit more specific?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 12, 2006 | 11:09 AM
Basttion's Avatar
Default okay, so if I had 5 and 10 mm adapters made, would that solve all the issues
or would the offset still wonk up the handling etc?
Old Feb 12, 2006 | 11:14 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Impossible...Why don't you drop this idea and..>>>
get proper wheels for the car? You can't make adapters that slim. You need to bolt them to the hubs....
<img src="http://images6.fotki.com/v1/photos/7/7305/43355/rspacer3-vi.jpg">
