my checking engine oil level light is on i need you guys help plzzz
Old Feb 12, 2006 | 06:15 PM
azn123's Avatar
Default my checking engine oil level light is on i need you guys help plzzz
my engine oil level light went on yesterday and i added oil in right the way .but the light is still on .i also check the Dipstick,it is showing proper oil level.i need help ...how to turn it off???
Old Feb 12, 2006 | 06:19 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Sometimes a bad Coolant temp sensor...>>>
will cause the oil light to illuminate...(Really)
JustAdam's Avatar
Default Not sure - but would that go on if you were overfilled?
****Tracking Thread****
Similar problem here, might just change out the oil level sensor?
Old Feb 12, 2006 | 06:20 PM
JustAdam's Avatar
Default Mine has already been changed - anything else?
I know this is not my post but I have a similar issue!
Old Feb 12, 2006 | 06:24 PM
azn123's Avatar
it's kind suck~~~~~~~~
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
From before or after all the recent oil pan work?
Old Feb 13, 2006 | 03:29 AM
JustAdam's Avatar
Default Well I am pretty sure that the
coolant sensor was changed out 6 months ago - but ever since I had the accident the oil light keeps coming on whenever it feels like.
I always stop and check my oil now but every time it is full already - can it be over-filled? Would that make the light go on again?
Old Feb 13, 2006 | 05:04 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Probably damaged the level sensor in the pan...>
Overfilling should not make the light come on..though low pressure may...
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 13, 2006 | 05:27 AM
Teutonix's Avatar
Low oil PRESSURE could also be causing the light.....
Old Feb 13, 2006 | 05:46 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Good point, especially for Adam....>>
I would get a gauge on that car ASAP and see what's going on with the pressure..
