Replacing the Brakes....>
Old Feb 13, 2006 | 06:20 AM
BierBurner's Avatar
Default Replacing the Brakes....>
I will be replacing the brake Rotors, Pads, Lines and fluid. I also will be painting the calipers.
Does anyone recommend any certain order to this. I was planing on taking everything off getting the calipers off and painted. Then installing the new lines, rotors, pads and new fluid.
Any suggestions.
Oh should I use some lithium grease for the caliper pistons? Or should they be good to go after cleaning them well. I will be using PBR ceramic pads by the way.
Old Feb 13, 2006 | 06:33 AM
Arheddis Varkenjaab's Avatar
Junior Member
Default no clue on the brake system but I do know how to get perfect calipers.
With the calipers off we took HEAVY duty scotch brite pads and roughed the surface. The first coat was red high temp engine paint. We applied several coats and then cooked the paint in a heat booth.
we then took a lite duty scotch pad and hit the surface of the red (this is when to apply the audi rings) and applied several coats of clear high temp paint.
I have taken a pressure washer to these things and they still look brand new
Old Feb 13, 2006 | 07:10 AM
SereniTTy's Avatar
Default I used the G21 paint system, painted the fronts off the car (stainless lines also) and the rears
on the car. They look about the same. I liked being able to diassemble and clean the fronts off the car. The rears are much simpler and workout just fine on the car. You also won't need to remove the rears to install the stainless lines.
PBR ceramics aren't bad, definately less dust. We'll see what happens to them on April at VIR.
Old Feb 13, 2006 | 07:11 AM
BierBurner's Avatar
Default good write up...>?
Thanks for the reply. So one question. After your final coat of red, you used a fine scotch pad and lightly scratched the surface. Then shot it with clear. So, no scratches were seen after you shot the clear?
Old Feb 13, 2006 | 07:31 AM
Junior Member
Default none. A paint and body guy gave me the pads. Worked perfectly!
i could send you the pads if you would like to try the same thing
Old Feb 13, 2006 | 07:40 AM
stilljester's Avatar
Member
I've used G21 in the past as well..It works great!!
Old Feb 13, 2006 | 09:45 AM
polishadonis's Avatar
Default I am doing the same thing this week with hawk plus pads, slotted rotors, ss lines...
and motul brake fluid. I was thingking it was a good time to paint them too. So i will. He means sand paper when he means scotch pads right?
Old Feb 13, 2006 | 12:42 PM
BierBurner's Avatar
Default Sure.. That would be great....>
Or send me the brand.
bishopu@gmail.com
 Pouria Savadkouei
 Michael S. Palmer
Sloooo4esT
Audi Original "S" Cars
May 30, 2005 11:25 AM
A4NCAR
17
May 17, 2004 12:50 PM
CTMechE
May 16, 2004 09:30 AM
Absolute Santorin
Jan 26, 2004 04:37 PM
fabva
Jul 20, 2001 08:15 AM
