Choosing aftermarket shocks: how do you know which type of shock properly matches our spring rates?
Old Feb 13, 2006 | 08:36 AM
rbl's Avatar
rbl
Default Choosing aftermarket shocks: how do you know which type of shock properly matches our spring rates?
Let's assume we're on stock springs. If the shocks aren't adjustable, then you're stuck with the fixed damp rate.
Old Feb 13, 2006 | 08:44 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Bilsteins are a very nice match on stock springs...>
Mine ws this way for awhile, and I've done one other.
Old Feb 13, 2006 | 10:10 AM
1T42T (aka ZZ CETT)'s Avatar
Member
Default Yup - Bilstein HDs- stock springs- beautiful combination.
Throw in the Neuspeed rear sway bar and you'll be
done.
s
Old Feb 13, 2006 | 10:37 AM
rbl's Avatar
rbl
Default I believe you guys, but was wondering how you knew to choose the HDs. >>>
It's odd that damping rates aren't part of a shock's advertised specs, you'd think that'd be the most important buying decision.
Old Feb 13, 2006 | 10:43 AM
joe@vwvortex's Avatar
Default Because HD's and Sports have the same dampening rate - only difference is shaft legnth
HD's are for stock springs - Sports are for lowering springs.
Old Feb 13, 2006 | 11:11 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default But either will work with either...>>>
HD's are 22mm longer in shaft length but work fine with moderate drops of 1 inch or so. I had HD's on stock springs and now on Eibachs. If going lower is in the plan, go for the sports.
Old Feb 13, 2006 | 11:58 AM
Member
Default I chose the HDs based on talking to a few local experts (Russ Scott) and reading lots of posts
Seemed this was the best bet for what I was looking
for - and it was! They may take a while to "settle" in, but provide a nice ride and a substantial
improvement in handling.
s
Old Feb 13, 2006 | 12:02 PM
But it's safer to just tell people to use the Sports when lowering :-)
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 13, 2006 | 12:11 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Yeah, with all the slamming going on around here.....:-(
a4avant99
Sep 2, 2009 02:27 PM
UrSoccer_mobile®
Oct 16, 2003 02:15 PM
Canadian_A4
Jun 29, 2003 09:26 AM
HoTTrod
Feb 3, 2002 09:35 AM
GrantlyS4
Jan 15, 2002 09:39 AM
