Creaking noise.. Where exactly do I lube the sway bar bushings?
Old Feb 13, 2006 | 08:59 AM
esanmiguel's Avatar
Default Creaking noise.. Where exactly do I lube the sway bar bushings?
My car is making horrible front creaking noise. Im pretty sure from reading posts here that its the sway bar bushings. I got some silicone spray and not really sure how or where to spray the stuff. Do I just spray all over the sway bar bushing? If so, how is that lubricating it?
the link below is a wav file of this annoying noise.<ul><li><a href="http://www.clearpaintguard.com/audi/struts2.wav">Creaking noise</a></li></ul>
Old Feb 13, 2006 | 10:56 AM
Trickle X's Avatar
New Member
Default To lube the bushings correctly, you should take them out & lube up....
If you look at the rear swaybar, you can see it better. But the bushings should come out &amp; you lube up the inside of the bushing with some sticky greese. Its the part that come into contact directly with the swaybar that needs lubed. I havent done my front yet, but I have done a couple of rears....
Old Feb 13, 2006 | 01:07 PM
jonchavez's Avatar
Member
Default Here's a pic of the front driver's side. The joint is all wet here with...
<center><img src="http://pictureposter.audiworld.com/43168/squeeky_bushings.1.jpg"></center><p>silicon spray lubricant. Just get that knuckle nice and wet with lubricant so it can soak in around the edges and take away the annoying sound. Works for me.
zarmstrong92
A6 (C7 Platform) Discussion
Jun 8, 2016 07:28 PM
S4AVT
Jun 22, 2006 04:48 AM
esanmiguel
Feb 18, 2006 01:11 PM
Neo1130
10
Nov 16, 2005 04:43 PM
Potomac2.7Tee
Jan 6, 2004 12:17 PM
