Hey Steve, problems after MOFO and 4bar.
Old Feb 13, 2006 | 10:05 AM
DisTTracted's Avatar
New Member
Default Hey Steve, problems after **** and 4bar.
After I installed the **** and 4 bar my car started having hesitation on acceleration like stuttering or hiccups then it threw a code system to lean... I figured the MAF went bad so I replaced it and cleared the code. but its back. any idea whats causing this? should I go back to my 3bar FPR? or is this the coil packs or something else?
Thanks!
Old Feb 13, 2006 | 10:18 AM
DasTT's Avatar
Default Stupid suggestion... is the MAF in the correct orientation? -->
****'s can go in both ways even though the MAF housing is keyed for direction.
Old Feb 13, 2006 | 10:28 AM
Jasper Lamare Crabbe's Avatar
New Member
Default yes but, the connector on the harness should let you know right away if the MAF is backwards.
The male connector orientation on the harness is difficult to rotate 180 if the MAF is installed backwards.
this should clue you in right away that it's in wrong
Old Feb 13, 2006 | 10:39 AM
New Member
the little notch/scoop is facing the intake. thats right?
Old Feb 13, 2006 | 10:40 AM
DasTT's Avatar
That's kinda why I thought it was stupid, maybe some engine harnesses give more latitude than others
New Member
the clip/lock is facing up.
Old Feb 13, 2006 | 10:41 AM
DasTT's Avatar
There's an arrow on the MAF that points in the airflow direction
Old Feb 13, 2006 | 10:43 AM
DasTT's Avatar
Default Another possibility of course is -->
the fpr is faulty, not actually giving you 4 bar above the control signal. Dirt, foreign object in the fpr, clogged screen could all give similar symptoms.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 13, 2006 | 10:46 AM
New Member
I' might order another to be sure. unless, can I clean it?
Old Feb 13, 2006 | 10:54 AM
modesTT@work's Avatar
Did ya flog it before adaptation period?
