Wheel spacer questions
Old Feb 13, 2006 | 10:51 AM
Trickle X's Avatar
New Member
Default Wheel spacer questions
I just finished over the weekend the KW v2 install. I have the car sitting about an inch lower than stock in the front and about .75" in the rear. On the front my wheels have about 3/16" from the rim to the coilover. I want to space them out for obviously clearance issues, but also to aid in the lowered look.
My wheels are 8.5" in width with 225/40/18 rubber on it. I want to space out the rims as far as possible for strut clearance & fender clearance. I was thinking of 12.5mm in the front & 20mm in the rear. Does anyone see an issue going this route? Also does anyone know what size rubber I can go to on an 8.5" rim? Any particular brand spacer I should go with/avoid?
Thanks!
Old Feb 13, 2006 | 10:59 AM
nikhil's Avatar
Default what is the offset of your wheels?
that will really dictate what you can and can't do with respect to spacers and tires.
Old Feb 13, 2006 | 11:02 AM
Seneb's Avatar
Default Offset calculator....
<ul><li><a href="http://2x.ca:8080/TT/offset/">Click me! Click me!</a></li></ul>
Trickle X's Avatar
New Member
Not sure, will hafta pull &amp; measure, wheels were already on car when i bought it
Old Feb 13, 2006 | 11:04 AM
nikhil's Avatar
what wheels are on there?
Old Feb 13, 2006 | 11:05 AM
Trickle X's Avatar
New Member
Thanks, I saw that when i did a search, but didnt know my offsets!
Old Feb 13, 2006 | 11:12 AM
Trickle X's Avatar
New Member
Default Not sure but here is a pic
<center><img src="http://pictureposter.audiworld.com/101466/riteside.jpg"></center><p>This is before I installed the coilovers...
Old Feb 13, 2006 | 11:50 AM
Trickle X's Avatar
New Member
Default Would this work?
I measure 1/2" or 12.7 mm in the fron from the edge of the wheel to the edge of the wheelwell. Cant I just use a 12mm spacer to offset the wheel that exact distance?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 13, 2006 | 12:09 PM
SereniTTy's Avatar
Default Looks like the flik artic in silver. There are a couple of wheels that look like that, Roja has one
If it's the flik, 35mm offset.
Old Feb 13, 2006 | 12:43 PM
Trickle X's Avatar
New Member
Thats the wheel!!! Thanks I have been wondering what they were!
