Suspension critique: This is whats going on the car,
Old Feb 13, 2006 | 04:36 PM
ItsJ's Avatar
Default Suspension critique: This is whats going on the car,
Ok tell me if this will create a nice suspension setup. I have an 02 225TT AWD manual. Will this create too much oversteer, because this car has no idea that such a thing even exists ;-)
1. HR coilovers (in route)
2. Nuespeed rear (19mm in route)
3. Haldex Performance Unit
4. 18 in RS4 reps with either 10mm or 15mm spacers in front and 20mm or 25mm spacers in rear, if someone can clarify the advantage having thicker thinner spacers, if there are any?
Old Feb 13, 2006 | 04:55 PM
Basttion's Avatar
Sounds good. Lots of people have gone down that exact path. ;o)
Old Feb 13, 2006 | 05:01 PM
ItsJ's Avatar
Default yeah i have seen similar suspension setups.. i don't want to bother with the
front sway bar, i heard it was a pain the a$$ to install
Old Feb 13, 2006 | 07:22 PM
Russ Scott's Avatar
Default ran that for a year... loved it!
well... 1, 2, and 3... I used 17 inch wheels though. Super flat cornering, NO oversteer problem, VERY quick turn in, and direction changes like a "fly". Decent ride, but on REALLY long road trips there was fatigue (hence my change to Bilstein/Eibach). Overall a high quality set-up that's dead reliable with the latest revision rear springs (all new kits for the last 2-3 years came with the correct spring). Uses revalved/shortened Bilstein dampers (they go forever, the worst set of Bilsteins I've had went 115k miles). The full range of ride height adjustment is available without tricks. I'd still be using the c/o's but I'm gettin' old, needed to slow down, and really like long tours...
Old Feb 13, 2006 | 08:19 PM
ItsJ's Avatar
cool thanks
joseaudi
S4 (B8 Platform) Discussion
Sep 15, 2009 08:43 AM
AmoKK
10
Feb 29, 2008 06:10 PM
picoolo
23
Jul 19, 2007 12:41 PM
joec500
A4 (B7 Platform) Discussion
10
Oct 10, 2006 01:16 PM
Small Town Terrorist
Suspension Tuning Discussion
Aug 28, 2006 11:37 AM
