Turning signal off
Old Feb 13, 2006 | 04:53 PM
Kuo's Avatar
Kuo
New Member
Default Turning signal off
My wondering my turning signal. When i turn on my turning signal, it is only on once and then off, but i can turn on my hazard (blinker) signal without any problem. Do you know what happen?
Old Feb 13, 2006 | 04:59 PM
MarTT's Avatar
Default Your turn signal relay switch is bad >>
you can replace it yourself or have the dealer take care of it under warranty. See link for how-to.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1193292.phtml">https://forums.audiworld.com/tt/msgs/1193292.phtml</a</li></ul>
Audiboy's Avatar
Default Are all your lights blinking with the Hazard? If so, it's most likely your turn signal relay
circuit, which is unfortunately part of the Hazard switch.
Old Feb 13, 2006 | 05:04 PM
Kuo's Avatar
Kuo
New Member
Default All my lights are blingking with the hazard
So what's wrong? where is the position of turn signal relay?
Old Feb 13, 2006 | 05:07 PM
MarTT's Avatar
See my post above ^^^^^^^^
Old Feb 13, 2006 | 05:10 PM
Kuo's Avatar
Kuo
New Member
The problem isn't the blinker signal
Old Feb 13, 2006 | 05:12 PM
msauve's Avatar
Default The problem is the turn signal relay...
which is part of the hazard switch.
Old Feb 13, 2006 | 05:13 PM
Kuo's Avatar
Kuo
New Member
Default yeah i saw it
Actually i can use my blinker with no problem at all.
The problem comes when i use my turning signal both left and right, it's only blink once before it's off.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 13, 2006 | 05:15 PM
Kuo's Avatar
Kuo
New Member
so turn signal relay is the same part with hazard signal
Old Feb 13, 2006 | 05:16 PM
MarTT's Avatar
Yes.
