Clutch Problems with the TT - Flatbedded but here are the symptons.....
Old Feb 13, 2006 | 05:17 PM
coasTTal's Avatar
Default Clutch Problems with the TT - Flatbedded but here are the symptons.....
TT was doing just fine and had been driving it alot today. Stopped for coffee and then noticed as I pulled away that the clutch pedal had very little pressure for the 1st half of travel. Gears were a bit tough to shift. Going through stop and go traffic I had the clutch pedal all the way to the floor to get it to disengage. Finally, the clutch would not disengage and the pedal went to the floor.
I was able to pull it off to a safe place and then waited over 2 hours to get a flatbed.
It would seem to me that this is something to do with the clutch hydraulic system and not pressure plate or clutch itself.
Extended warranty should pay for the repair.
TT has 74K on it.
Old Feb 13, 2006 | 05:19 PM
MarTT's Avatar
Ugg - sorry to hear that John. Hope all is resolved soon. Let us know.
Old Feb 13, 2006 | 05:38 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Ooops....Sounds like the clutch slave John...>
YOu haven't been too lucky recently...
Old Feb 13, 2006 | 06:04 PM
coasTTal's Avatar
Default Well, at least I was not on my way to a TT event, but almost went to one on Sunday.
Just glad I have an extended warranty.
Old Feb 13, 2006 | 06:37 PM
Jasper Lamare Crabbe's Avatar
New Member
sounds like about a $500-700 problem, might as well do the clutch then too, about $300 more
Old Feb 13, 2006 | 07:18 PM
AmarilloA4's Avatar
New Member
Default I feel your pain, I just got up the courage to replace mine.
turned out to be the slave cyl.
You might try bleeding it and check for leaks. If your loosing fluid the pedal will react as you described.
Omski
Aug 26, 2006 10:42 AM
ePuFFy
Nov 18, 2004 05:01 AM
BowBow
Feb 26, 2002 05:48 PM
Clutch
Nov 7, 2001 09:40 AM
Lexx
11
May 14, 2001 09:36 AM
