Forge fmic
Old Feb 13, 2006 | 09:49 PM
NyQuaTTro's Avatar
New Member
Default Forge fmic
I just bought a forge fmic 4 my 180hp was wondering if any body could give me some feed back and pics of engine shots. also do ineed to relocate my dv to install the cooler
Old Feb 13, 2006 | 10:12 PM
Blue TTop's Avatar
Try the search function. I got 416 hits in the TT forum with "fmic 180". Good luck w/the install.
Old Feb 14, 2006 | 02:43 AM
LiTTespeed's Avatar
Default unless the 180 is radically different from a 225 you shouldn't have to relocate the DV...
<center><img src="http://pictureposter.audiworld.com/18189/fmicon.jpg"></center><p>here's a pic of the day we did my 225 on my last car, for apples to oranges reference
Old Feb 14, 2006 | 04:10 AM
TTinCT's Avatar
Rest In Peace
Default Basically...it is the same as a 225 if you bought the whole kit>>>
The 180 uses a 225 manifold, so a FULL FMIC kit is aa bit bigger job than a 225. DV relo is not needed, but can be done...but it is a little more involved than the 225.
<img src="http://www.forgemotorsport.com/images/products/FMINTTT180.jpg"><ul><li><a href="http://www.forgemotorsport.com/content.asp?inc=product&amp;cat=0108INT&amp;produc t=FMINTTT180">http://www.forgemotorsport.com/content.asp?inc=product&amp;cat=0108INT&amp;produc t=FMINTTT180</a</li></ul>
Old Feb 14, 2006 | 04:17 AM
GorTT's Avatar
Default I still haven't done my DV relo, but as has been said before, it will be tight.
<center><img src="http://pictureposter.audiworld.com/53277/dscn4120.jpg"></center><p>
here's a top shot after install, showing the hose snakeing in front of the batt, and the throttle body relo; evoheatshield also done at the same time, btw.
pdxTT
Oct 9, 2003 02:40 PM
TTRPM
May 27, 2003 06:35 AM
A34eva
Nov 16, 2002 02:39 AM
Uncle Silvio
Jan 15, 2002 06:52 AM
