what vw r32 can use 2 wheel dyno
Old Apr 13, 2006 | 06:50 AM
HCK's Avatar
HCK
New Member
Default what vw r32 can use 2 wheel dyno
EIP TUNING STAGE 4 R32 TURBO VIDEO
TT can use it ???<ul><li><a href="http://www.eiptuning.com/eip/video/R32/EIP_R32_600_HP_0001.wmv">VIDEO DOWNLOADS</a></li></ul>
Old Apr 13, 2006 | 06:52 AM
nikhil's Avatar
yes
Old Apr 13, 2006 | 06:59 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default None.......>
Unless you disconnect the rear driveshaft. There will be potential for Haldex clutch damage otherwise....Pulling fuses doesn't disable the mechanical pumps.<ul><li><a href="http://www.wak-tt.com/haldex/haldexfuse.htm">Response from Haldex on this issue</a></li></ul>
Old Apr 13, 2006 | 07:05 AM
nikhil's Avatar
so technically, a tt could do that....it's just more work than pulling a fuse...
Old Apr 13, 2006 | 07:07 AM
nikhil's Avatar
oh, and ygm in a sec Steve
Old Apr 13, 2006 | 07:35 AM
HCK's Avatar
HCK
New Member
Default Tks ~ Modshack
so tt can do that ?
i want to try BOSCH Dynamometer but my friend only 2wheel dyna.
Old Apr 13, 2006 | 07:46 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Do you mean...>
Disconnect the shaft? Sure..
Old Apr 13, 2006 | 08:00 AM
HCK's Avatar
HCK
New Member
u mean must be Disconnect rear driveshaft ??
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 13, 2006 | 08:13 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Yes
Old Apr 13, 2006 | 08:19 AM
HCK's Avatar
HCK
New Member
how to disconnect ??
