Care had noticable hesitation this morning at around 2000rpm (longish)>>
Old Apr 13, 2006 | 08:04 AM
TTDirk's Avatar
New Member
Default Care had noticable hesitation this morning at around 2000rpm (longish)>>
Also notice that the car seems flat or choked on initial acceleration from standstil, until about 2500 rpm is reached. I noticed this before since it got Revo'd and wrote it off to the boost being so much more noticable at higher RPM.It does not stutter so does not seem to be a misfire. Main recent difference is that the weather was a lot cooler than yesterday, but not as cold as two weeks ago. Oh and I did wash the car last night, including engine bay.Good thing I did, coz its raining today. I'll check for DTC's with Vag-com, but, where should I start looking if its not gone by tonight? Would appreciate some advice, thanks, Dirk.
Old Apr 13, 2006 | 08:05 AM
TTDirk's Avatar
New Member
Oops I mean Car of course
Old Apr 13, 2006 | 08:38 AM
Jasper Lamare Crabbe's Avatar
New Member
How many miles? Plugs, points, condensor, oh and a new distributor cap. Spring tune-up you know.
Old Apr 13, 2006 | 08:44 AM
jhoeppel's Avatar
Good point--important to flush/replace the condenser fluid at this time of year.
Old Apr 13, 2006 | 10:19 AM
TTDirk's Avatar
New Member
Of course, What should the points gap be again?
Old Apr 13, 2006 | 11:55 PM
Breitling's Avatar
New Member
Default I had the exact same problem!
had to take it to the dealer 3 times and leave it overnight each time until they finally could replicate my complaint as no codes came up. they did a few things including, cleaning the throttle body, replacing the spring on the valve gate to the turbo? anyways, the car apparently has a lot more boost and seems to run better, although, the problem doesn't seem to have completely disappeared....i'll wait and see how things continue.
raaizin
Dec 13, 2015 07:41 AM
Niketalk1
Q7 MK 1 Discussion
21
Aug 3, 2010 04:08 PM
chicagoA6
Feb 11, 2005 08:52 AM
the dude abides
May 13, 2003 05:31 PM
jmdp
13
Dec 4, 2002 08:09 PM
