Oil Cooler leak..........anyone have experience with plumber's paste?
Old Apr 13, 2006 | 10:53 PM
M power this!'s Avatar
Default Oil Cooler leak..........anyone have experience with plumber's paste?
Earls Lines said to use it instead of tape. one fitting is NOT sealing! i've tried twice today and it just seems to blow thru the stuff. anyone got any ideas? it's on the return to the stock filter location. maybe it has more pressure than elsewhere? but then, wouldn't the system equilize as far as pressure? this is pissing me off!
Old Apr 14, 2006 | 03:07 AM
GeTT da NeTT's Avatar
Both sets of threads have to be clean and dry. Honestly, I think the tape would be better
Old Apr 14, 2006 | 04:07 AM
fignewton's Avatar
Default And, I think that there is a specal teflon tape for use in petroleum applications
not just the white stuff you find in the plumbing section of Lowes/Home Depot.
Good luck!
fig
Old Apr 14, 2006 | 04:59 AM
Default Look here (or for similar)
<ul><li><a href="http://www.electrotape.com/thread-seal-tapes/threadseal.html">get'er done</a></li></ul>
Old Apr 14, 2006 | 05:26 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default AN fittings?
Sounds like they're assembled wrong or there's a defect in the hose. Did you make up the lines? I would take the end off, cut an inch off the line and re-assemble.... I've made 2 full sets of lines for coolers and never had one leak yet..
If the defect is the seating surfaces of either the male or female you might want to look at that. AN fittings are designed to seal with little tightening due to the precision mating of the parts. If the leak is there you may have to tape the treads. I would think that would be better than paste, but fixing the root of the problem would be better than both..
<img src="http://images7.fotki.com/v118/photos/8/89907/3372260/P3240164-vi.jpg">
<img src="http://images17.fotki.com/v296/photos/8/89907/3372260/P3240158-vi.jpg">
Old Apr 14, 2006 | 09:14 AM
Blue TTop's Avatar
Default AN fittings are the way to go. That and some yellow teflon tape worked for me.
<center><img src="http://images15.fotki.com/v264/photos/1/168597/2875693/DSC02442-vi.jpg"></center><p>
Old Apr 14, 2006 | 11:54 AM
Thanks. took it off, and the female adaptor plate had a hairline..........i feel alot better
Old Apr 14, 2006 | 12:28 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Great!
 Pouria Savadkouei
 Michael S. Palmer
20VT90q
Oct 22, 2008 09:21 AM
VW-Quantum-Man
Feb 20, 2007 09:50 AM
RobC
Jul 17, 2006 01:37 PM
v8phil
Mar 16, 2004 07:53 PM
scott12v@pghaudi
Performance and Tuning
15
Nov 7, 2002 05:26 AM
