I STA. Still have question regarding hardwiring power to XM receiver.
Old Apr 14, 2006 | 05:00 AM
Silvr_Surfr's Avatar
Member
Default I STA. Still have question regarding hardwiring power to XM receiver.
I have a Delphi Myfi receiver. It is a portable unit, not a dedicated car receiver, and it gets it's power through the cigarette lighter outlet. I would like to hardwire the power for less hassle and a cleaner look. I couldn't find anything in the archives, but I don't think many people have this particular unit.
Is there a way to cut the lighter adapter off and connect the wires to some circuit. If so how do I do this? If not, any suggestions on what else I can do?
Thanks for helping a novice.<ul><li><a href="http://shopdelphi.com/consumers/satradio/myfi/details/specifications/">http://shopdelphi.com/consumers/satradio/myfi/details/specifications/</a</li></ul>
Old Apr 14, 2006 | 05:25 AM
Astronut's Avatar
Default You might try this...
<center><img src="http://store1.yimg.com/I/yhst-54608124176281_1890_1085896"></center><p>Look around on the site to see what else is available. I have a SkyFi in the TT and a MyFi in the Touareg. With the SkyFi I'm just using the cassette adapter and I kludged the lighter adapter by soldering wires to it, wraping it in electrical tape and hooking the wires into power at the fuse panel. I then buried the whole mess behind the center cubby. All that shows is a couple wires snaking up along the ashtray. For the MyFi in the Touareg I used a PIE aux. input adapter that also supplies power.<ul><li><a href="http://www.myradiostore.us/power-accessories/hardwired-xm2go-myfi-airware-tao.html">Hardwired Car Adapter for XM2go Delphi MyFi / Tao / Pioneer Airware</a></li></ul>
Old Apr 14, 2006 | 06:10 AM
Member
Default Thanks. That's exactly what I need. Now all I need to know is where a 12volt
DC power source is to splice into. I don't have a TT wiring diagram and the only electrical experience I have is changing light fixtures in my house.
Or do you have any pictures of where and how I can hook up to the fuse panel?
Or should I just get a professional to install it? I know TT electrical systems can be tempermental and I don't want to anger mine.
Thanks again.
Old Apr 14, 2006 | 07:01 AM
Astronut's Avatar
Default It looks like the kit includes two wire taps...
You just need to find appropriate +12v and ground wires under the console to crimp onto. Not sure where without looking myself. Others here may be able to help with that.
I used some red &amp; black hookup wire, a fuse tap and quick disconnect lug from radio shack and tapped the right side of fuse #8 in the fuse box (top left most fuse). I ran the wires through the console (remove the knee bolster) and fed them into the space behind the center cubby. I have my radar detector and XM tied into this circuit.
Here's a pic of the setup. Unfortunately I don't have a picture of the fuse tap. I'll try to take one later and post it.
<img src="http://pictureposter.audiworld.com/46158/p4140003.jpg">
Old Apr 14, 2006 | 07:52 AM
TTeleven's Avatar
Default You can tap in here
<center><img src="http://pictureposter.audiworld.com/11/tc.t.jpg"></center><p>
Old Apr 14, 2006 | 09:54 AM
GoTToGo's Avatar
Junior Member
Default I used a 12V to 6VDC transformer to hardwire the power to the ignition key switch.
I tapped into a switched power fuse in the fuse box, ground it on the brown nut under the steering wheel.
Do not cut your power cord wire and wire directly to a 12V source. You need a transformer to feed it 6V. From your specs link, yours looks like it needs 5V-2A.<ul><li><a href="http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&amp;ProdID=1990">I think you need this...</a></li></ul>
gabatta
Audi allroad
Aug 21, 2007 04:18 AM
GDawgA4
Nov 18, 2006 06:36 AM
jtntsfr
Aug 28, 2005 03:34 PM
German Driver
Jan 1, 2005 02:40 PM
NoahD
Aug 21, 2001 05:30 PM
