Suspension questions regarding Kmac (Full or half) and Forge adj. tie bars
Old Apr 14, 2006 | 06:44 AM
JustAdam's Avatar
Default Suspension questions regarding Kmac (Full or half) and Forge adj. tie bars
Do I need both?
I am going to do some suspension possibly and I want to know if I need both of these:
<img src="http://www.ttstuff.com/images/forge/FMAUTB_540.jpg">
Forge Adjustable Tie Rod Bars for the rear on TT-stuff.com
<img src="http://www.ttstuff.com/images/kmac/KMAC-FL_540.jpg">
Full K-mac kit also on TT-stuff.com
My question is do I need both or do I only need one or the other?
FYI, I have H &amp; R sports and Bilstein shocks and the TT needs an alignment bad and @ the same time I do this I want to do the Ground Control in the front too.
Any help would be appreciated - so I understand what I am doing before I do anything!
Old Apr 14, 2006 | 07:11 AM
coasTTal's Avatar
Default I used half a kit on the rear. GRD did it for me.
Also looking into the ground control kit.
Old Apr 14, 2006 | 07:12 AM
EvotechTT's Avatar
Junior Member
Default Hey Adam I noticed you finally got your body kit on...How do you like it? How are the fitments?
Was there any problems fitting it?
Old Apr 14, 2006 | 07:22 AM
RoberTT-WWCD's Avatar
Default Adam, You don't need both. I have the full K-mac as I had toe-in problems...>>
They are cheaper than the forge but take a while to install. You have to press the old bushings out. Where as the forge is just a replacement.
Hope this helps.
Old Apr 14, 2006 | 07:30 AM
Kareem of Elise's Avatar
You don't need both...just go w/ the full K-mac and you should be fine
Old Apr 14, 2006 | 08:02 AM
JustAdam's Avatar
Thanks John - hope to see YOU tomorrow!
JustAdam's Avatar
I LOVE IT - Only minor fitment issues from what I heard from the body shop
Old Apr 14, 2006 | 08:03 AM
JustAdam's Avatar
So if I went with the Forge the instal is easier, but it does the same thing?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 14, 2006 | 08:10 AM
Yes it does.
Old Apr 14, 2006 | 08:51 AM
coasTTal's Avatar
Default Not going now - Too many things to do at home
I've paid, and if you feel the need, you can use my payment if they will let you. Eamil Dave or Brian
