worn tie rods...
Old Apr 14, 2006 | 11:27 AM
gio's Avatar
gio
Junior Member
Default worn tie rods...
I just had my steering rack replaced. The total came to $1485 which is much cheaper than what the dealer quoted me. When replacing the steering rack, they noticed that my tie rods were word -- something that I've been told for about a year now every time I have my tires swapped or an alignment done. I really wanted to get them replaced as it wouldn't cost me any extra for labor (they had to take out the old tie rods and do an alignment anyways, of course) but I didn't have the $360 to spend for the parts. I really regret not doing it, but I didn't have a choice right now.
I'm probably going to end up getting new tire rods in a month or two anyways (when I have more money), which will require another alignment (ugh). In the meantime I've been looking around and I've realized that $180 per tie rod is ridiculuous and there seems to be a some aftermarket alternatives, some of which are a third of the price (or less). Does anyone have any experience using other than Audi tie rods in their TT? Is it a bad idea? Which ones do you recommend? I'll do anything to save a little money right now.
Old Apr 14, 2006 | 11:36 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Tie rod ends..($20/each)....>>
Which is the part that wears...<ul><li><a href="http://autohausaz.com/search/productx.aspx?sid=r3f1um45js45oq45h3z3o5ak&amp;mak eid=800002@AUDI&amp;modelid=1368277@TT%20QUATTRO%2 0&amp;year=2001&amp;cid=26@Steering%20System&amp;g id=7428@Tie%20Rod%20End">AutohausAZ</a></li></ul>
Old Apr 14, 2006 | 11:42 AM
gio's Avatar
gio
Junior Member
Default Re: Tie rod ends..($20/each)....>>
yeah, I saw those. Last time I remember they recommended I just replace the ends. I wonder why they didn't say that this time. How much time labor should it be to replace the tie rods (or the ends) not including the alignment?
Old Apr 14, 2006 | 12:24 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Pretty easy...>>
Pop them off with a tool, unscrew, screw on new ones, re-attach at the hub, set Toe...
Really it's only a 30 minute job not including alignment and you'll only need a toe adjustment after...
Old Apr 14, 2006 | 12:25 PM
OldSchool AG's Avatar
Senior Member
Default I could probably do both sides in an hour.... figure paying 1 hr per side at a shop...
plus alignment as you mentioned.
Old Apr 14, 2006 | 12:36 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Slacker!
Oh, I forgot....I have a lift!
Old Apr 14, 2006 | 12:39 PM
Senior Member
Default that helps...
closed today... may be dropping a bit of cash on one of them portable scissor lift thangz pretty soon... if there's any money left over after carpet paint appliances hvac etc etc...
Old Apr 14, 2006 | 12:40 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Congratulations! I was wondering how that was coming along..
Trust me, with your little side activities it will pay for itself in no time..
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 14, 2006 | 01:07 PM
Senior Member
Default Thanx...
that's definitely true...I gotta find my old post where I found that good price on it.
Old Apr 14, 2006 | 04:14 PM
MaxHedrm's Avatar
Congrats! The ultimate TT mod. :^)
RC200
Wheels & Tires Discussion
Mar 21, 2010 11:54 PM
red90q
Jan 10, 2009 04:31 PM
ltooz_a6_a8_q7
Mar 6, 2006 07:56 AM
AJN334
9
Nov 22, 2005 04:09 PM
cmRobin21
Sep 22, 2004 08:31 AM
