A tad pricey - but finally upgraded sidemount intercoolers - direct replacement
Old Apr 15, 2006 | 07:49 AM
joe@vwvortex's Avatar
Default A tad pricey - but finally upgraded sidemount intercoolers - direct replacement
for stock. 60% increase in size over stock. For those that don't want a FMIC.<ul><li><a href="http://www.hpamotorsports.com/products_turbo_components_intercoolers.htm">HPA dual sidemounts</a></li></ul>
Old Apr 15, 2006 | 07:52 AM
l33tt's Avatar
Default Very interesting. Sal?
I'd love to hear your thoughts, comments.
Old Apr 15, 2006 | 08:17 AM
Lowcountry's Avatar
Default Did you do the install yourself? If so, got any details?
I'm very interested in doing this myself. I don't really want to go the FMIC route.
Old Apr 15, 2006 | 09:48 AM
CHRG IN's Avatar
Default Why?
<center><img src="http://pictureposter.audiworld.com/46648/forge_fmic.jpg"></center><p>I can see the advantage of not blocking the Radiator, but the air flow is all twisted this way, not to mention the coolness factor of how the FMIC looks. After you get rid of the side mounts you end up with the perfect location for your auxiliary Oil Cooler.
Old Apr 15, 2006 | 10:59 AM
ar design's Avatar
2nd
Old Apr 15, 2006 | 11:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I'm assuming...>
You have no plans for intake air feeds or outboard oil coolers?
Old Apr 15, 2006 | 11:50 AM
gtt's Avatar
gtt
Good for a 180 w/single side mount?
Old Apr 15, 2006 | 01:02 PM
Default Well - you could run the oil cooler in the middle - but a good point on the intakes
but not a bad alternative to the FMIC.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 15, 2006 | 01:03 PM
Default Nope - just saw them on the HPA page - not sure what route i'm going to take
but at least there appears to be a good smic alternative out there.
Old Apr 15, 2006 | 01:42 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Well - you could run the oil cooler in the middle - but then....>
Your just blowing the heat you went to a lot of trouble to isolate from the cooling system right back into it through the radiator...
Many Years ago a UK guy tried and had some high speed heat issues...He relocated it to the side and everyone since has as well (except for Gil and Rafft I believe)
No soup for you!
