Will the timing belt turn if one tooth off?
Old Apr 15, 2006 | 10:51 AM
TTest-D3MON's Avatar
Default Will the timing belt turn if one tooth off?
I decided to do the timing belt myself this weekend since the shop I took the car to totally blew off my appointment on Wed. So everything has been going alright, and ive just put the timing belt on (thank god for the tip to just put the belt over the water pump and screw that in). So after all these warnings I keep reading about being one tooth off, Im really scared now. I rotated the crank 4 times, and it seems to turn ok besides the pressure on compression. So i just want to know if its even possible to be able to turn it if it was off a tooth? Already scared myself once when i first started to turn the crank sprocket though. Turned the crank a little and then it stopped, figured I must have screwed up....until my vise grips fell off from the top of the cams! DOH!
Old Apr 15, 2006 | 11:22 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup....Check your marks to be absolutely sure....>
I take it you didn't put additional marks on the belts and pulleys? Too late now. Use the factory marks
Old Apr 15, 2006 | 11:33 AM
I did, just worried. Oh well, here goes nothin....pin pulled
Exemplify
May 25, 2018 02:11 PM
discocontented
A4 (B7 Platform) Discussion
Aug 13, 2016 01:13 AM
old96A4
May 18, 2012 01:40 PM
mosmoe (OPG)
13
Jun 25, 2007 04:02 AM
Mark - Steve's bro'
Audi 100 / A6 (C4 Platform)
May 11, 2004 06:10 PM
