Question about lug bolt length and aftermarket wheels >
Old Apr 16, 2006 | 07:10 AM
GorTT's Avatar
Default Question about lug bolt length and aftermarket wheels >
Is there a 'standard' wheel lug seat thickness, so that for any given wheel that fits a TT - for example - is the lug bolt length the same (shape of seat - ball or conical - aside), or do they tend to be different? For instance, is the bolt length the same between the 6-spoke and the fat fives, and/or is that the 'same' length as required for an OZ or BBS wheel - given NO spacers, of course? Tia.
Old Apr 16, 2006 | 07:41 AM
joe@vwvortex's Avatar
Default Stock bolts are 28mm ball seat - measured from the bottom of the seat to the end of the bolt
conical SHOULD be measured the same way. It's basically the legnth of the threads.
Old Apr 16, 2006 | 08:10 AM
GorTT's Avatar
Default Thx, Joe; not quite the question. Does an aftermarket wheel, such as BBS or OZ >
or your NS ALSO use a 28mm, is what I'm trying to find out, and since that's dependent on the casting thickness, is there a 'standard'?
Old Apr 16, 2006 | 08:18 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Never seen that spec.......
I would assume most wheels are different depending on the Strength, casting spec, depth of lug hole drilling etc. Default should always be measured by # of threads into the hub..
Old Apr 16, 2006 | 08:26 AM
GorTT's Avatar
Default as you probably inferred >
I'm soon to be the proud owner of some aftermarket wheels. I guess they're cone seat (BBS RE's), and I do run spacers. What I'd like to do is just order one set of lug bolts for a given spacer thickness and have them arrive about the same time as the wheels, and - I know it's asking a lot - actually have them be the right length the first time...
Since nearly everyone on the forum (but me!) has bought new wheels, I was hoping this had some knowledge base. :-|
Old Apr 16, 2006 | 08:40 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Doesn't John have those?...>
(LZ7 Variety) RE's? try him for info!
Old Apr 16, 2006 | 08:42 AM
GorTT's Avatar
Default ok, will do. >
there was a post at the beginning of April by 'Buddydog' - I asked by post last night, but nothing back yet.
Old Apr 16, 2006 | 09:40 AM
Default I know all my BBS wheels in the past have used ball seat lugs and I used my OEM bolts
doesn't mean the RE's do as well - but I would bet they do. Just add the spacer length to 28mm and you'll be fine. That's worked for me on all my wheels over the years - ball or cone seat.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 16, 2006 | 09:52 AM
GorTT's Avatar
Default Ah - thanks! Was sure it wasn't too big a deal or there would be posts on it >
"but you never know" ;-)
Old Apr 16, 2006 | 10:40 AM
JohnLZ7W's Avatar
Default Nope mine are SX
but as Joe says below they use the stock lugs, ball seat and 28mm length.
