Hey Steve...Boost Machine tuning question...>>>
Old Apr 16, 2006 | 12:01 PM
I8ABUG's Avatar
Default Hey Steve...Boost Machine tuning question...>>>
The Boost Machine is installed, and it is set at 4-1/2 turns on the boost valve and 1 turn on the onset valve. Boost peaks at about 22 and settles in at 19-20 (on an APR chipped 225Q). The car is definitely much better than before the install.
Your instructions say not to push it much above 22...do you mean peak boost or what it settles in at?
Thanks!
And for those of you thinking about getting a Boost Machine, I highly recommend it. It is a super easy install. If I can do it, anyone can!
Old Apr 16, 2006 | 12:36 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Peak...Sounds like you have it set perfectly!
Old Apr 16, 2006 | 03:03 PM
Blue TTop's Avatar
Interesting... I'm set at 5-1/2 turns on the regulator to peak at 22psi. Outside temp difference?
Old Apr 16, 2006 | 03:13 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Partially...>>
Plus you're setting to a desired pressure point. Regulators are not precision instruments in that # of turns will never be the same from valve to valve. They are adjusted to the desired pressures within thier range....There is always some variability...
Old Apr 16, 2006 | 03:29 PM
Blue TTop's Avatar
And elevation should play a part too.
Old Apr 16, 2006 | 03:35 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Yup, since it's pressure differential...
cookie28b
S4 (B8 Platform) Discussion
Mar 6, 2017 05:34 PM
andrew.tt
18
Oct 29, 2005 01:42 PM
audi4k
Audi Original "S" Cars
Oct 24, 2005 09:43 PM
jae shin
Apr 5, 2004 01:46 PM
DirtyVegasTT
Feb 8, 2004 02:04 PM
