What is the part number for the pre-cat oxygen sensor on a MY2000 ATC 180hp ?
Old Apr 19, 2006 | 09:47 AM
DuTTCH's Avatar
Default What is the part number for the pre-cat oxygen sensor on a MY2000 ATC 180hp ?
I'm getting an 'B1 S1 Internal Resistance too high' and the car misfires badly at WOT
Old Apr 19, 2006 | 10:01 AM
RoberTT-WWCD's Avatar
Default Same as mine...:-) Anyways...>>
You might be pushing too much boost. I get the same error when I push over 21psi. The misfires could be bad plugs or coilpacks.
I can't remember if you are MS SIII. If you have the BM, dial it back a little.
Just a thought. It still could be the O2 sensor.<ul><li><a href="http://www.autohausaz.com">Might be here...</a></li></ul>
Old Apr 19, 2006 | 10:39 AM
DuTTCH's Avatar
Default I am at a 127k miles so it's probably overdue.. Can't find it on that website though..>>
do you have the part number?
Old Apr 19, 2006 | 10:48 AM
Default I have it a home. ECS has one for the ATC for $174.95...>>
It's the front/primary sensor.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=180HP&amp;mo del=TT&amp;submodel=Quattro&amp;category=Engine">O 2 Sensor</a></li></ul>
Old Apr 19, 2006 | 12:22 PM
OldSchool AG's Avatar
Senior Member
Default you can also use this one... for about $20... 06A 906 262 Q
the cable is a little longer but that's the only difference AFAIK
Nogaro Stg3
Jul 25, 2006 04:19 PM
MelloYelloS4:Indkted
9
Mar 2, 2004 05:08 PM
X - 1 _ r a c e r
Jul 11, 2003 12:00 AM
lskolnick
Audi Original "S" Cars
9
Jun 9, 2003 09:08 PM
Vtec_Killer
Feb 1, 2002 01:43 PM
