Question to people with Motive Power Bleeder - Air Pockets in Bleeder's Tube
Old Apr 19, 2006 | 10:58 AM
Costa Osadov's Avatar
New Member
Default Question to people with Motive Power Bleeder - Air Pockets in Bleeder's Tube
I used my Motive Power Bleeder for the first time past weekend. Pressure help up; everything bled quite nicely dark fluid with a bit of debris out first then clean one; afterwards brake pedal feels firm; clutch pedal certainly feels a bit smoother. BUT, one thing did not look quite right to me. Bleeder tube never filled uniformly with fluid and all through the procedure I had large pockets of air cleary present in the tube. Things out of the bleeding valves were coming out just fine though - no air bubbles or interruptions. This puzzles me. Sent email to Motive people and was assured that it was normal as "The air pocket that you are seeing in the line is completely normal. You are seeing this there because the pressure is displacing the air in the reservoir with fluid from the tank."
I would appreciate feedback from folks here who are using Motive Power Bleeder - do you guys have air pockets in the line too? Physics is not my speciality obviously. Thank you.
Old Apr 19, 2006 | 11:41 AM
TTagz's Avatar
Senior Member
yep, nothing to worry about, it won't introduce air into the lines
Old Apr 19, 2006 | 03:48 PM
J. Patterson's Avatar
Default Ditto on the "not a problem"
The power bleeder simply pressurizes the reservoir and supplys fluid to it as fluid is depleted by bleeding the calipers. An air bubble fed from the power bleeder would stop when it reaches the master cylinder reservoir. There is always an air space at the top of the reservoir. (At least there should be. don't overfill.)
KRUPNATION
Audi allroad
Sep 14, 2010 05:19 AM
McLaren
Canadian Discussion
Mar 28, 2008 08:39 AM
CoopSil00S4
Mid Atlantic Discussion
Mar 9, 2008 05:21 PM
EmeraldCityBoy
Dec 16, 2002 09:45 AM
NullTerminator
Aug 9, 2002 12:36 PM
