Weird..Got in the car today and my gas gauge needle is bouncing up and down
Old Apr 19, 2006 | 01:12 PM
esanmiguel's Avatar
Default Weird..Got in the car today and my gas gauge needle is bouncing up and down
Today was a hot day about 77 degrees. Got in the car and not the key is not even in the ignition as I noticed the gas gauge needle doing a little "dance" for me. I sat inside the heat of the car amused by this phenomena. I sat there for a couple of minutes almost laughing at what Im seeing. Then the humor stopped as I realized the several posts I have seen about failing clusters. It even got less funny thinking the fix for the cluster is like $700+. Then it got downright ugly realizing I may not even have that $700 in a few months because of a guy name Prashant is learning my job to take back to IBM in India. I swear, I just want to kick this car sometimes.
Old Apr 19, 2006 | 01:25 PM
|everso!|'s Avatar
Default paint an american flag on the roof! QUICK!
there is no time to waste.
Old Apr 19, 2006 | 01:34 PM
aTTicism's Avatar
Default My brother used to say: "Smile, things could be worse. So, I smiled...
and sure enough, they got worse."
It may only be the fuel sending unit. Try the TTSchwing Chevron techron with techroline treatment. Maybe it will settle down.
If not, and you don't want to spend $$ to fix, figure out how many miles per week you drive before fueling, and fill up based on mileage, not the gas guage.
Old Apr 19, 2006 | 01:37 PM
esanmiguel's Avatar
Default Re: My brother used to say: "Smile, things could be worse. So, I smiled...
Actually the gauge is way off. I go by the digital readout on how many miles I have left till empty (that seems to be accurate). So this means it may be the sending unit? I dumped two bottles of Techron on a near empty tank on it already with no luck.
Old Apr 19, 2006 | 01:48 PM
Natty Boh's Avatar
New Member
Default Just in case
I did this about 2 months ago...has been working great and it was $250<ul><li><a href="http://www.bba-reman.com/index.aspx">http://www.bba-reman.com/index.aspx</a</li></ul>
Old Apr 19, 2006 | 01:51 PM
TonyStarkz's Avatar
Default I had the EXACT same problem a few weeks ago....
Not a bad cluster; but a dirty fuel level sender. I thought i would have to take it out and clean it; but with the advice of schwing and a few others I ran few tanks of chevron techron fuel injector cleaner and it was fixed.
Old Apr 19, 2006 | 02:07 PM
esanmiguel's Avatar
Default Re: I had the EXACT same problem a few weeks ago....
You mean you had your needle bounce up and down even when key is not in ignition? And how much techron should I put in ?
Old Apr 19, 2006 | 03:01 PM
TonyStarkz's Avatar
wait...maybe i misread...you mean the key is not even in the car at all? or just not started?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 19, 2006 | 03:04 PM
esanmiguel's Avatar
the key is NOT even in the ignition switch.
Old Apr 19, 2006 | 03:17 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Bad JuJu....
