Tried search on this. Temp gauge all the way to H. A/C turns off then back on.. pump or sensor?
Old Apr 19, 2006 | 09:02 PM
alberttien's Avatar
Default Tried search on this. Temp gauge all the way to H. A/C turns off then back on.. pump or sensor?
Temp sensor goes all the way to H. The A/C stops working then turns back on after a few min but the gauge cluster still shows H. Now is this the temp sensor, water pump, fan? I checked the fan and it is on when the car is overheating. What else could be wrong?
Old Apr 20, 2006 | 03:44 AM
msauve's Avatar
Default Yes...
pumps (at least the original plastic impeller ones) and sensors are both common failure items. Try the sensor first (do a search), they're cheap (~$5) and easily done.
Old Apr 20, 2006 | 04:57 AM
Rocky-in-Connecticut's Avatar
Default is coolant pumping back into the resevoir?
if you rev the engine does coolant return back into the resevoir? If not then your water pump is shot. In the meantime if you still have a black engine coolant temp sensor then replace with a new green one.
Old Apr 20, 2006 | 05:04 AM
OldSchool AG's Avatar
Senior Member
Default Could be pump, thermostat, sensor, or instrument cluster>>
and it's not a good idea to run the car AT ALL with the gauge pointing to "H" until you know if it's really overheating or not.
S4_Rocksnow
Dec 5, 2007 11:47 AM
ROMTT
Aug 24, 2006 07:09 PM
Biscuit141
Audi 100 / A6 (C4 Platform)
Apr 10, 2004 09:00 AM
omaha90
Apr 5, 2004 01:22 PM
xjrpilot
15
Oct 9, 2001 07:33 PM
